Хто буде з регіонів?
Moderators: rahmanoff, koluchka, М.и.т.я.й
Хто буде з регіонів (не партіі) ?
приеду с регионов
15
56%
приеду из Киева
12
44%
Total votes: 27
Re: Хто буде з регіонів?
Biker wrote:а у меня почему-то http://www.alfa-day.com не открывается, а работает только http://alfa-day.com/
Все открывается
Вот только если попробовать зарегистрироваться то получаешь такое:
Traceback (most recent call last):
File "/usr/lib/pymodules/python2.5/cherrypy/wsgiserver/__init__.py", line 624, in communicate
req.respond()
File "/usr/lib/pymodules/python2.5/cherrypy/wsgiserver/__init__.py", line 357, in respond
response = self.wsgi_app(self.environ, self.start_response)
File "/home/piranha/svarga/svarga/core/handler.py", line 74, in __call__
mw.process_response(request, response)
File "/home/piranha/svarga/svarga/db/sqla/backend.py", line 104, in process_response
env.sqla.session.commit()
File "/usr/local/lib/python2.5/site-packages/sqlalchemy/orm/session.py", line 671, in commit
self.transaction.commit()
File "/usr/local/lib/python2.5/site-packages/sqlalchemy/orm/session.py", line 378, in commit
self._prepare_impl()
File "/usr/local/lib/python2.5/site-packages/sqlalchemy/orm/session.py", line 362, in _prepare_impl
self.session.flush()
File "/usr/local/lib/python2.5/site-packages/sqlalchemy/orm/session.py", line 1354, in flush
self._flush(objects)
File "/usr/local/lib/python2.5/site-packages/sqlalchemy/orm/session.py", line 1432, in _flush
flush_context.execute()
File "/usr/local/lib/python2.5/site-packages/sqlalchemy/orm/unitofwork.py", line 261, in execute
UOWExecutor().execute(self, tasks)
File "/usr/local/lib/python2.5/site-packages/sqlalchemy/orm/unitofwork.py", line 753, in execute
self.execute_save_steps(trans, task)
File "/usr/local/lib/python2.5/site-packages/sqlalchemy/orm/unitofwork.py", line 768, in execute_save_steps
self.save_objects(trans, task)
File "/usr/local/lib/python2.5/site-packages/sqlalchemy/orm/unitofwork.py", line 759, in save_objects
task.mapper._save_obj(task.polymorphic_tosave_objects, trans)
File "/usr/local/lib/python2.5/site-packages/sqlalchemy/orm/mapper.py", line 1268, in _save_obj
connection = uowtransaction.transaction.connection(self)
File "/usr/local/lib/python2.5/site-packages/sqlalchemy/orm/session.py", line 261, in connection
return self._connection_for_bind(engine)
File "/usr/local/lib/python2.5/site-packages/sqlalchemy/orm/session.py", line 318, in _connection_for_bind
conn = self._parent._connection_for_bind(bind)
File "/usr/local/lib/python2.5/site-packages/sqlalchemy/orm/session.py", line 329, in _connection_for_bind
conn = bind.contextual_connect()
File "/usr/local/lib/python2.5/site-packages/sqlalchemy/engine/base.py", line 1229, in contextual_connect
return self.Connection(self, self.pool.connect(), close_with_result=close_with_result, **kwargs)
File "/usr/local/lib/python2.5/site-packages/sqlalchemy/pool.py", line 151, in connect
agent = _ConnectionFairy(self)
File "/usr/local/lib/python2.5/site-packages/sqlalchemy/pool.py", line 304, in __init__
rec = self._connection_record = pool.get()
File "/usr/local/lib/python2.5/site-packages/sqlalchemy/pool.py", line 161, in get
return self.do_get()
File "/usr/local/lib/python2.5/site-packages/sqlalchemy/pool.py", line 525, in do_get
c = self.create_connection()
File "/usr/local/lib/python2.5/site-packages/sqlalchemy/pool.py", line 122, in create_connection
return _ConnectionRecord(self)
File "/usr/local/lib/python2.5/site-packages/sqlalchemy/pool.py", line 198, in __init__
self.connection = self.__connect()
File "/usr/local/lib/python2.5/site-packages/sqlalchemy/pool.py", line 261, in __connect
connection = self.__pool._creator()
File "/usr/local/lib/python2.5/site-packages/sqlalchemy/engine/strategies.py", line 80, in connect
raise exc.DBAPIError.instance(None, None, e)
OperationalError: (OperationalError) unable to open database file None None
Все открывается
на тот момент не было пофиксено. сейчас все пучком
Smile
Автомобиль: 156 1.9JTD
Post by Smile »
Извините, братцы, но концепция поменялась. 26-го надо будет уезжать из Киева. Может хоть где вас встречу, обсигналю.
ЛевДенис
Post by ЛевДенис »
кАпец!!!
КАК МОЖНО???
совесть ваще есть???
прошу лишить меня звания Альфа-зародыша)))
Smile
Post by Smile »
Сам локти кусаю. Раскатал губу, что в Киеве покатаюсь.... Около мамки с альфистами сфотаюсь.... Ага... Но вдруг концепция еще раз успеет поменяться) Я не теряю надежды :crazy:
Return to “RADUNO D’AMICI 2010”
